sharp ar-m700u
  • T911
    • Jun 2007
    • 628
    sharp ar-m700u
    anyone have the part number for the felt cleaning roller in the fuser for the larger upper fuser roller. it's not in the parts manual.
  • glewisme
    • Nov 2009
    • 240
    AR703RC is the number for the cleaning roller kit
    • T911
      • Jun 2007
      • 628
      I guess u can't just order the i've cleaning roller?
      • kvilaysing
        • Oct 2010
        • 41
        You can trying calling 877-777-5001 ask for sharp's part specialist. I think they can help you there, with the part number, you might be able to order it from them too.
        Good luck, hopefully this help.
        • T911
          • Jun 2007
          • 628
          Thanks for the help guys
          • glewisme
            • Nov 2009
            • 240
            It's in MFP-TB-194 I'm pretty sure it this # NROLN1730FCZZ, UPPER CL ROLLER N2 cost is $45.98.Just so you know the AR703RC from Sharp is only 34.78
            • Dark Helmet
              • May 2009
              • 845
              You are aware it's cheaper to replace this fuser than rebuild it right? (Assuming you do upper, lower, sub heat and cleaner kit)
              AR703FU1
              • T911
                • Jun 2007
                • 628
                I didn't know that the fuser was cheaper I will look into it thanks again guys
                • glewisme
                  • Nov 2009
                  • 240
                  Sharp for the most part has excellent pricing on components.Order it as a consumable item ART703FU1 it's cheaper at $282 compared to part#DUNTW7305DS88 at $359.20.!!!!!WAY CHEAPER!
                  • Dark Helmet
                    • May 2009
                    • 845
                    It does feel some what wasteful to replace the entire thing but it comes down to every thing is NEW.
                    • glewisme
                      • Nov 2009
                      • 240
                      Amen no oops ah shit I just dropped my screwdiver on the heat lamp,or something like that!
                      • Dark Helmet
                        • May 2009
                        • 845
                        haha been there done that! 2 hours out of town on a old 35 ppm minolta analog and i broke the lamp
                        The replacment lamp came in a bubble pack envelope to haha.... 4 day turn around
                        • glewisme
                          • Nov 2009
                          • 240
                          AHHH could it be an old EP3050 Ha!! Believe it or not I have a customer who refuses to upgrade his EP4050 still.
                          • Dark Helmet
                            • May 2009
                            • 845
                            No idea what Minolta called it, Pitney cloned it and called it a C350. Drum and DV came out on this big frame if i remember right.
                            • glewisme
                              • Nov 2009
                              • 240
                              Oh yeah that's it an old EP3050 what a pig!
