ARM317 dotted line on copies
  • gwaddle
    • May 2009
    • 782
    #16
    Originally posted by CopierTechofOmens
    Models: AR-M257 / AR-M317
    Priority
    Medium
    Date:
    August 2009
    Subject:
    Getting dotted lines front to rear when making copies using the RSPF and the OC.
    Symptom:
    Cause:
    Integrated circuit breakdown.
    Solution: Replace the MCU.
    Thanks, I missed that.
    I know I should be ashamed of myself. Strangely though, I am not.
    • Dark Helmet
      • May 2009
      • 856
      #17
      Yesterday a guy called me about a ARM277 that was giving blank copys, print jobs are fine. I mentioned the problem here and maybe he should take a main board with him. Scan to email worked fine, but copys came out blank. He replaced the board including the IMC (removed every thing from a scrap copier) and it fixed the problem. He swapped IMC boards but could not replicate.
      Gwaddle you helped fix our problem
      • gwaddle
        • May 2009
        • 782
        #18
        I've ordered a main board, but it's back ordered at this point till January.
        • Sharpshooter
          • 21
          #19
          Check the grid of the main charger corona!!!
          • gwaddle
            • May 2009
            • 782
            #20
            I replaced the main charge.
            • gwaddle
              • May 2009
              • 782
              #21
              Priority
              Medium
              Date:
              August 2009
              Subject:
              Symptom:
              Cause:
              MCU fixed it. Thanks to all for the input.
