H5-01 on a AR-C260
+ More Options
Posts
  • tmanamore
    • Sep 2009
    • 74
    [Error Code] H5-01 on a AR-C260
    What is the error code H5-01 on a AR-C260 and how do i reset it?
  • JustManuals
    • Jan 2006
    • 9838
    This Parts & Service manual can now be purchased for $11.77 and downloaded immediately after payment from The Internet's largest collection of manuals
    Paul@justmanuals.com
    • OMD-227
      5 continuous jams at fuser.
      Common causes are something obviously blocking paper path at fuser or in inverter unit, a deformed or toner contaminated reverse gate, toner buildup on POD1 sensor arm causing extra POD1 sensor activation, sluggish transfer belt rotation causing irregular paper speed into fuser or damaged fuser exit guide rollers causing no paper drive after fusing (these were modified years ago though).
      Check all these things, then run sim 14 to reset this trouble code.
