AR-168 H-codes
  • ebm
    • Apr 2007
    • 183
    AR-168 H-codes
    Multiple AR168 machines are popping H3 & H4 codes on us. Everything checks ok w/the fusers,replaced thermistors,reset codes. Sometimes the codes reoccur a few days later. Anyone else having H-code problems? Any ideas? The old SF-models used to have triacs that would fail and give H3(high heat), easy to tell because the lamp would be on constantly. H4 (low heat)codes would almost always come from a failed lamp. Never really experienced erroneous codes being generated before.
  • TennWalker
    • Apr 2007
    • 72
    On these smaller machines such as the AR-153 and AR-168 the fusers carry a different part number. I have experienced a problem when the copier comes out of "preheat" mode, the toner would rub off the first copy. This would not occur from a cold start. It turns out, I was ordering the wrong part number for the specific model, even though they physically look the same.
    Has any other tech adjusted the fuser temperature settings 43-01,04,05,14 or insure that they are at their default settings.
    I hope the above helps in some way.
    Take Care
    I thought I was getting wiser as time went on... I now realize I am just getting older.
    • ebm
      • Apr 2007
      • 183
      The fusers are the original, only the thermistors were replaced. No adjustment made to fuser temperature.
      Thanks for the reply.
        • 22996
        These will blow the thermal switch. In many cases I have changed only the thermal fuse, and did not re-occur. The H3-00 and H4-00 do usually occur after coming out of energy saver, and most of the time there is no apparent reason.
        • vlad_robas
          • Oct 2006
          • 225
          i got plenty of H4 on AR-5316 reason is the get out of energy for various reasons like: plug out before turn off storm that cuts the line of power off...
