mx2310
  • OMD-227
    #16
    Here's a big tip.
    DO NOT put the toners in before running 25-02 on run-up.
    Install the devs (NO TONERS INSTALLED), then run 25-02, then install toners afterwards.
    Also, in the field, same thing...... when replacing devs, remove the toner cartridge for that particular dev, until the dev adj is completed.
    You'll get EE errors galore if you miss this step. You'll have no choice but to replace the dev again.
    Everything has been tried & tested in getting around this, but its a small price to pay.
    I personally always have the toners out on run-up & dev replacement, but now it is pretty much compulsory.
    • glewisme
      • Nov 2009
      • 240
      #17
      Yeah I always setup the 26/31/41/5001n without toners installed. It's a good idea to do on the 23/27/35/4501 as well. Do you have many out in the field yet?
      • OMD-227
        #18
        Yeah, I cant tell you exactly how many, but I remember we did run-ups a few weeks back and there was alot of guys each working on several machines each.
        Now its even more stock to cart around, because everything is different again with this series.
          • 23009
          #19
          So what ever happened with that "cross-platform compatible parts" Sharp was spouting 5 years ago? It sounded like a great idea, just never gonna happen. =^..^=
