MX-M550N Scanning issue
  • tmanamore
    • Sep 2009
    • 74
    I Have a Sharp MX-M550N with the print/scan. The scanner is listed as Standard but when i press the IMAGE SEND button, the display says "Option Not Installed". Why is this?
  • bonnie750
    • 302
    i haven't ever seen this message but could be its not enabled with the activation code.
    • Dark Helmet
      • May 2009
      • 853
      Enter the key ops and go to the last page and go to product key. Check to see if Network Scanning is highlighted (black).
      If it's not you don't have the key inputed.
      • wtroll
        • May 2008
        • 85
        Hallo,
        the ethernet scanner is not standard on this model.
        You must have an MX-NSX1 (10 license Scan Kit) and activate it with the related procedure.
        At this time your Scan Kit will forever follow the machine serial number and you cannot activate it on another machine.
        • xmasvn
          • Jul 2009
          • 70
          you can use mode 26-10 to check the trailer this scan function, usually if the scan kit have been install in your photo this will be coming with image scan function on panel
          • OMD-227
            Wtroll is right here. You need the NSX1 kit for network scanning on the Dragon2's.
            Check 22-10 to see if network scanner is activated. If not you need to buy the NSX1 kit.
