sharp ar 507 error
  • tongee
    • Nov 2009
    • 50
    sharp ar 507 error
    help me sharp ar 507 error code E7-11
  • bonnie750
    • 302
    Hello
    It's shading trouble (white correction).
    Bill
      • 23006
      E7-11: Content Shading trouble (white correction)
      Detail Improper CCD white reference plate
      reading level for copy lamp lighting
      Cause Improper installation of flat cable to CCD unit
      Mirror, lens or reference white plate contaminated
      Copy lamp operation error
      Improperly installed CCD unit
      CCD unit error
      ICD PWB error
      Check and remedy:
      Clean mirror, lens, or reference white plate.
      Check copy lamp for light amount (SIM5-3) and lighting.
      Check CCD unit.
      Check ICU PWB.
      (it's usually ends up being the ICU PWB, but try the cheap stuff first)
      This code was the scourge of the Cougars. =^..^=
      • tongee
        • Nov 2009
        • 50
        ok thank
