sharp ARM355N and reset
  • kelly923
    I just bought an old Sharp AR-M355N Gray scale Copier but I need to connect it to a network, I cannot access the network settings, because the operator code has been changed from the default is there a way to reset it? someone suggested I should be able to reset admin password using simulation 24-9 but it didn't work, can anyone please help me or does someone know how can I do a factory reset (and should I do that) so I can start new,
    I am a newbie so any help in simple steps would be greatly appreciated
    Thanks,
    Kelly
  • ZOOTECH
    Senior member of CRS
    • 3375
    Sim 22-7 will get you the key op number; it can be changed afterwords in the key op menu. If you are accessing the embedded web page and that admin password has been changed, you can do a NIC reset from the MFP and reset the log in to default.
    • kelly923
      ZOOTECH,
      Your the best!!! THANK YOU So Very Much!!!!!
      Kelly
