Sharp AR 161 Displaying L6
  • vonhetcchtel
    • 42
    [Error Code] Sharp AR 161 Displaying L6
    Hi,
    I have a customers sharp AR 161 that is displaying error code L6.
    Please help us dignose this problem and also direct us on fixing it.
    Regards,
    Von
  • ZOOTECH
    Senior member of CRS
    • 3375
    If the sub code is '10', then it is a LSU polygonal motor problem. You could get by with just the motor replacement, but to access and replace the LSU (it's a PITA), it would be advisable to replace the whole unit.
      • 22995
      Agreed. =^..^=
      • oldrn
        • 166
        If you ignore Sharp's LSU removal instructions, you can change the polygon motor in these fairly easily without pulling the LSU. This is assuming there is no job separator tray installed. The biggest problem with pulling the LSU is getting the back screws out since they are blocked by the circuit boards. If you remove the op panel and front panel, you can slide the delivery tray out the front. The LSU cover has 2 security torx screws in it that require a hollow tip torx bit. Once the cover is off of the LSU or even just raised enough to get a short phillips in there, you can replace the polygon motor.
        After having repaired many L6-10 codes by replacing only the polygon motor, I just had one that required the entire LSU to fix it.
        • montana
          • Aug 2008
          • 393
          hi....L6..polygon motor trouble....
          • NEOTECH
            • Dec 2010
            • 69
            yap laser unit problem
            • chakiris
              • 22
              Originally posted by vonhetcchtel
              Hi,
              Regards,
              Von
              I agree with Blackcat
              • DINGO
                • 661
                In my case, all the "l6-10" in this models,i decided to replace the poliginal motor, and works ok.
                good lucky
