Sharp error code
  • luis8832
    • Dec 2008
    • 250
    [Error Code] Sharp error code
    I am working on a Sharp MX-3501n. As i turned it on it comes to the ready condition. After a couple of seconds it gives me a L4-30 error code. This is my first time working on a sharp copier so i have no information on this copier. I need to know what this code stands for and how i can clear it. Also if anyone has a service manual on it and a parts manual it would be greatly appreciated.
  • OMD-227
    L4-30 is Controller Fan Motor failure. That is the small fan which is near the MFP board. You can visually check if it is rotating with the back cover off. If it is rotating, but throws the code, you have a return signal fault within the fan most likely. You can also run the fan in simulation 6.
    My experience with most of the L4 fan codes is always a dead fan circuit. They get power to rotate, but no return signal to the PCU saying they are rotating, especially in your case where the code comes up a few seconds later.
    There is no specific procedure to clear that code, as its a fan problem. Once the fan is working or its replaced, upon startup you will not get the code.
    • luis8832
      • Dec 2008
      • 250
      thanks i removed the back cover and found the fan unplugged from the board. Thank you for your input it helped me out alot. unit is up and running. again thanx
      • OMD-227
        Wow, never seen one completely unplugged before..... thats unusual. Glad its working though.
          • 23008
          I've heard of situations like this. Unable to collect that check for past due clicks, the machine suddenly develops an error code. Hopefully you'll get paid, Luis. =^..^=
          • luis8832
            • Dec 2008
            • 250
            funny
            i like that, past due clicks. I have a feeling thats what the previous technician was doing. It landed on my lap and thanks to the input recieved it is working. Thanks u guys for all your help.
