MXM550 Maintenance Required message
  • Shishcabob
    • Aug 2025
    [Error Code] MXM550 Maintenance Required message
    I've been out of the industry for a while. I have a "Maintenance Required" message on a MXM550n I just can not get rid of.
    I reset 24-4, 24-5, 24-7. What have I missed?
  • ZOOTECH
    Senior member of CRS
    • 3377
    Your fuser web roller needs to be changed (I think).
    • travi
      • Jan 2008
      • 129
      There is asensor in the Fuser Web Assembly that tells you Maintenance Required when the fuser web has reached its end. When you replace the web make sure you have the actuator under the web or you will still get the message.
      • OMD-227
        Yep, the guys are right. You need to replace the web. This over-rides the clear counter, so if it has been cleared, it will still show maintenance. Make sure the web is installed correctly, or the sensor will still show maintenance.
        You need the MX705KC fuser maintenance kit (or a new fuser unit).
        • Dark Helmet
          • May 2009
          • 864
          If you have not already changed the fuser rollers, just replace the entire fuser using a supply number (MX705FU1), works out about the same.
          • toppower
            If you do not replace fuser web roller immediately , may damage the the Fuser unit.
            • CBMWilson
              • Sep 2010
              • 53
              That machine also has a count down counter for the web, so once you do replace it don't just put zero in the web count or you'll still have the same maint message. If memory serves should be rated for 300k, which is the same as the rest of the consumables in the fuser. (HR, PR, etc)
              • Shishcabob
                That was the counter I was looking for. Is it under sim24?
                • vincent64
                  • 382
                  You cant clear this maint code from sim, once you replace the web cleaner rollers in the fuser unit, and get the web over that sensor arm, it will go away.
                  The kit you need for a machine in USA is MX-705 RC.
                  Be sure you change the cleaner rollers in the fuser unit, the rollers that clean the lower fuser roller, they get built up with toner, and can lock the lower roller.
                  They are in the kit also.
