AR-M277 Pulliing Developer
  • tmanamore
    • Sep 2009
    • 74
    I am working on a Sharp AR-M277. I did a developer change and performed an automatic developer adjustment. About 4 days later, ther machine is pulling developer on the copies and around the transfer unit. Is there something else that should have been do to properly calibrate it?
  • OMD-227
    Did you replace the MC unit? When I ever did a PM on any AR or ARM machine, I always replaced drum, dev, blade & MC unit together as a set and I never, not once, had any problems with dev pull. I've read alot of stories over the years about machines pulling dev, and the root cause was always either a MC unit or drum problem.
    • CBMWilson
      • Sep 2010
      • 53
      We've had lots of this series machines that just loved to pull developer (and dump it into the bypass tray). It was almost always attributed to either a bare spot on the drum or a problem with the charge.
      • Akitu
        Legendary Frost Spec Tech
        • Oct 2010
        • 2595
        Sorry to necro the thread but I had a similar issue. A 317 was dumping dev into the whole frame, turned out the DV seal above the MG roller had folded in on itself and created a lip for the dev to ride up on and start dumping all over the place. Could have been that as well, something I always check now since my last post about it
        • bigrobmass
          • Aug 2015
          • 7
          Re: AR-M277 Pulliing Developer
          have this problem every once and awhile, when i first started it seemed like one every week. im thinking about starting to replace the mc unit more often. i was trained to clean it, if seems ok leave it , but it seems it would be cheaper to place it then to spend the time cleaning all that dev out
