Sharp Desk Shared to a Citrix Server
  • iscott
    • Mar 2010
    • 344
  • tmaged
    Owner/Service Manager
    • Oct 2008
    • 1887
    If you go into the network scanner tool, you can create as many profiles as you need to move them directly to shares.
    Hope that helps !
    -Tony
    www.dtios.com
    Become a fan on Facebook
    • xmasvn
      • Jul 2009
      • 70
      in your photocopy installed the OSA to intergation with Citrix Server
      • jettaround
        Re: Sharp Desk Shared to a Citrix Server
        Sharpdesk itself is a multi-user application so it can be used in a terminal server environment such as Citrix. The Network Scanner Tool on the other hand is not a multi-user application so you'll have to find a different method to deliver scans from the MFP to Server. With such an old machine you'll end up scanning to 3rd party FTP like IIS or other.
