Needed Service Manual for Finsher
  • LaserSharp
    • Sep 2007
    • 94
    Sharp- AR-BC260 Finshisher continues to give error F1-15
    Could really use a service manual on this one, and perhaps a place for parts.
  • JustManuals
    • Jan 2006
    • 9838
    What is the model number of the finisher?
    Paul@justmanuals.com
      • 23006
      AR-F13
      Its an AR-F13 and I've got it. Send a private message w/ email address. ETA: 24hrs.
        • 23006
        Oh, yeah! F1-15 is a tray lift error.
        1) Trash can or some other obstacle blocks movement of the lift tray. Move the trash can.
        2) Someone bumps the tray while its lifting. Turn Off/On to reset.
        3) The finisher is lifted by the tray. The tray brackets become bent up. As a result the tray misses the actuator on the flat part of the left side of the finisher. Most of the time the brackets can be straightened. In a few cases they were just too distorted. I replaced those.
        4) Customer falls on the finisher. Same effect as #2 except bent down instead of bent up.
