Unknown
  • Dzeak21
    • Oct 2007
    • 43
    Unknown
    I have a Sharp AR 507, While i was changing the Display I Shorted the machine out. I Changed the AC power supply, the Dc Power Supply, The Printer control Board and the ADF Board and also the Baord under neath the hard drive. i got the maichine up and running but the Display will Show the Machine has a ADF but then goes away before warm up. Anyone have any Answers for me. The machine has an ADF
  • JustManuals
    • Jan 2006
    • 9838
    Let me get this straight, you were changing the display with the power on? You should look into a career change.
      • 23006
      PCU PWB or EEPROM
      If the PCU was a new/good one there's really only one thing left: the PCU EEPROM. Usually its the PCU PWB that causes an accessory to vanish. If the PCU PWB that you installed was not new, It could easily have its own problems.
      I remember, I was trying to make (1) good working machine from (2) AR-287's and (1) AR-407. There wasn't a good PCU in the lot of them.
      • 10871087
        • Jan 2005
        • 1062
        Ouch!
        If the machine wasn't dead before you started I would guess that you pinched a wire somewhere.
