MXM850 trouble F4-38
  • Smrekca
    • Jan 2011
    • 23
    Hi,
    i have problems with a Hercules MX-M850. when i turn it on, the machine gives me an F4-38 trouble. this should be an 38V problem. did anyone has got the same problem and how can i solve it?
    plese help?
  • bonnie750
    • 302
    from the manual.
    Detail 38V voltage fall or 38V disconnected.
    Section PCU
    Cause Connection failure or disconnection of the connector
    and the harness.
    PCU PWB trouble.
    Power unit trouble, or blown fuse.
    HL PWB trouble. (relay)
    Check &
    Remedy
    Check the connector and the harness of the power line.
    Check the power voltage of 38V in the power unit and
    the PCU PWB.
    Check for blown fuse in the power unit.
    (Main power: F208
    Bill
    • OMD-227
      Check the HL pwb. CN6 pins 1,2,3 should have 38V, CN7 pins 6,7,8,9,10 should have 38V.
      The main power supply, powers the HL pwb. Check fuser 208 on the main power supply.
      Havent had this one myself yet, but keen to know the outcome.
      • Smrekca
        • Jan 2011
        • 23
        hello,
        i have checked all the fusers and they are all ok, i changed the hl pwb but no success. do you think that the main power supply is damaged?
        i think i will have to order one to check, becuose it is my only such device.
        thanks
        • OMD-227
          Yes, replace the main power supply. A check of the circuit diagram shows that all 38v lines come off that board. That is more likely than the PCU board being bad & not detecting the 38v line.
          Did you check the pins I listed above? That is the incoming 38v line to the HL pwb from the main power supply. It should be a dead giveaway.
          • OMD-227
            Any chance of an update on this one?
            Would love to know what the problem was, incase I see it here too.
            • Smrekca
              • Jan 2011
              • 23
              hello,
              sorry for my late reply.
              i changed the main power supply and the trouble dissapear.
              thanks for help wazza
              BR
              • spardigas
                • Jun 2021
                • 2
                Re: MXM850 trouble F4-38
                can anyone give the part number for the power supply
                • spardigas
                  • Jun 2021
                  • 2
                  no one knows where i can get a main power supply for mx-1100
                  • mloudy
                    • Oct 2015
                    • 770
                    I spent a while looking for it in the Parts Manual but could not find it. I am sure it is in there but Sharp doesn't always name their parts what I think they should be. As I don't work on this model I also do not know where it is to be able to visually find it in the diagrams.
