ar-m451n E7-90
  • DINGO
    • 661
    ar-m451n E7-90
    Good night
    I have a ar-m451n, that sometimes gives me the error code E7-90?
    appreciate any help.
    thanks
  • Dark Helmet
    • May 2009
    • 854
    Found this tip.
    Model Name:
    ARM350,ARM450
    Symptom:
    Machine Gives A E7-80 Or E7-90 Fault Code Or Blank Copies Or Paper Jams
    Cause:
    Static discharge in the PS Roller Unit
    Action: Ensure that the contact points of items 36 and 18 on page 5 of the parts
    guide are clean. Also ensure that items 23 are clean.
    • DINGO
      • 661
      thanks friend
      in my case, is a ar-m451n, but i will chek.
      regards
      • Dark Helmet
        • May 2009
        • 854
        Originally posted by DINGO
        thanks friend
        regards
        I think it's the same machine. It uses a 100k drum and 100k DV.
        • OMD-227
          It can definitely be caused by a missing earth spring in the rego unit.
          • DINGO
            • 661
            big hug, thank you all.
            • OMD-227
              Group hug everyone............
              • lky1978
                • Mar 2009
                • 483
                yes, i faced the problem also. the ps unit inside got 2 earth springs,one spring missing also can cause e7-90,machine hang up
                • DINGO
                  • 661
                  problem solved, revision to the unit of ps roller, and firmware upgrade, because the copier was out of date. (yet v. n1.12)
                  thnaks one more time.
