please help me
  • sarif
    please help me
    I can't solve the problem.
    what does E7-11 code mean on sharp AR-286?
    thank you.
  • JustManuals
    • Jan 2006
    • 9838
    You have a problem with the white correction. Time to call a service man.
    Paul@justmanuals.com
      • 23007
      E7-11 is a white level shading correction error. This code was intended to identify a dirty white level reference (located under the left edge of the copyboard glass).
      This code has plagued certain individual Cougar machines. I have personally replaced CCD's, installed a foam damper to the top of the hard drive (to damp vibrations between the hard drive and the lens cover), and ICU boards, to no effect. Typically 3 to 7 times a day this code can pop up.
      This will be an excellent opportunity to pull your hair out.
      • vlad_robas
        • Oct 2006
        • 225
        e7
        it can also solve by itself or can be caused by sun rises to drop in scaner areea and determine that error, g luck with it
        • gherkin
          Scanner lamp. Lamp wears out over years of use and is not bright enough for the machine to get a white reference reading (also check your white references under the glass for discolouration and dirt)
          • Sharpshooterbds
            • Aug 2007
            • 10
            thank you.
            This error is commonly caused by a faulty copy lamp. Although it lights it's not bright enough sometimes. This can cause the error code to come and go
