ar-m451n restart?
+ More Options
Posts
  • DINGO
    • 661
    ar-m451n restart?
    headache
    ar-m451n, give jam paper error and after taking out the jammed paper, the copier restarts and lose all the work?
    appreciate any help, if possible
  • OMD-227
    Dingo,
    Check the TC spring is in place correctly. PG section 3, item 18. Same for both Tiger & Jupiter series.
    The problem of restarting during a jam condition, blank pages, jamming in general and trouble code E7-90, are all associated with that spring not located correctly or missing. There is a static buildup (no ground) on the PS paper guide A.
    • DINGO
      • 661
      Wazza thanks, I'll check again.
      • DINGO
        • 661
        I'm out of luck, i chek all, and the copier gives me, E7-90, same paper jams, and continues restart.
        • OMD-227
          If you're sure the TC spring is intact in the PS unit, check the grounding of the machine.
          Your trouble code, jam conditions & restarting is always associated with that spring. Its gotta be mate!
          maybe even try another PS unit.
          • DINGO
            • 661
            I suspect a bad ground at the office, but I'm confused because I have more ar-m450n in the same office and no codes.??
            i will see, thanks
            • DINGO
              • 661
              No luck, I tried everything, and the problem persists.
              paper jam, and after the copier restart and loses all work.
              well.........
              • OMD-227
                Have you replaced the PS unit?
                Everything I've ever seen or known regarding this issue was always to do with the PS Unit & spring.
                Just throwing ideas into the ring now.......
                Move the machine to a different location/power lead in the room.
                Make sure firmware is up-to-date.
                Replace/Format the HDD.
                Or.....
                PCU flashrom is corrupt. Replace it.
                This one is a long shot, but there are mentions of it regarding other E7-90 problems. Doubt they are related, but I have seen MX color machines throw up 'Main Program Error' messages & restarts every few weeks, eventually traced fault to PCU flashrom as well.
                • DINGO
                  • 661
                  wazza,
                  I already did the following:
                  ps roller unit checked careful, not changed, hdd was formatted, firmware was up-to-date, and changed the power lead to.
                  • igi
                    • 1507
                    hi i had few copiers with similar problem
                    it was the heater unit
                    ta
                    • DINGO
                      • 661
                      friend, can you specify better what the problem in the heater unit?
                      thanks
                      • igi
                        • 1507
                        hi
                        it was faulty termistor or termistat one of them the quikest will be just to swop the units to verify
                        tanx
                        • divad2k1
                          • Sep 2010
                          • 147
                          Is your copier on a network ? If so, try to unplug network cable.
                          Had a couple of machine giving me weird problem like copier rebooting, hanging up, trouble code E7-xx.... and the problem was coming from the network( blowned up switch, garbage etc)
                          • DINGO
                            • 661
                            hi,finally solved the problem.
                            after having tried everything, and have replaced the PS roller unit, hdd format and change, take away fn6, and so, i again insist on the opinion of wazza, and traded unit back for a third ps roller unit, and the problem was solved. wazza, you were right, thanks friend, and thanks to everyone who tried to help.
                            post here the solution for serving the other members too.
