word 2007 printing issues(Sharp)
  • Dustin(WOP)
    • 223
    Hello all
    I am having some troubles with an MX-2600N printing from Word 2007 on 64 bit Win7. When you go to print and try to go to properties this message comes up: "Windows can not display the properties because of device configurations." or if you just say print it says "can't print file because printer has returned an error." I have uninstalled the driver 3 times and it still will not print. all configurations are correct within the configuration tab of the print driver also. I have changed soft switch in 55-3 switch 9 data 5 to a 1, and also disbled snmp to no avail. Has anyone ever seen this? Or anyone that can lead me in the right direction? Thanks in advance!!!!!
  • OMD-227
    The processing of the time data obtained from the Windows OS, may result in the print spooler crashing (unable to open properties) under the following conditions:-
    a. 64bit Operating System only.
    b. When using the MX series PCL6 or PS custom driver only.
    c. PC/Server is running all the time and the customer prints using the custom PCL6/PS drivers after approx. 11-50 days since the PC/Server was started.
    If the above symptom is experienced, upgrade the MX series print driver with the following version (or higher):-
    PCL6: 05.02.38.243 PS: 05.02.40.243
    • Dustin(WOP)
      • 223
      You the man wazza~!!!!!!!!
      • OMD-227
        Just install the very latest. Never use the version on the CD that comes with the machine. God only knows how old that is.
          • 23008
          I just had this conversation Monday. A customer wanted to buy a driver disk like the original that came with the machine. =^..^=
