ar-m451n memory information
  • DINGO
    • 661
    Hi
    I am working in a ar-m451n, and i need to do a memory upgrade, but i do not know what kind of memory is and where is locate.
    Same information i' m glad.
    thanks a lot
    • 23006
    Are you talking about fax memory? If yes, and if this is a Tiger, it takes AR-MM9 Memory Module 8MB. =^..^=
    • DINGO
      • 661
      Hi, mate,
      I refer to printer, and where it is placed? it is like the ar-m450n?
      stay well
        • 23006
        From what I can tell from the brochures it's a Jupiter. In that case, the fax still uses AR-MM9 Memory Module 8MB.
        The System Memory is:
        SHP16X64S133SC3-B Memory DIMM 128MB or
        SHP32X64S133SC3-B Memory DIMM 256MB
        There is 64MB on board, and you can add up to 256MB, for a total of 320MB
        It's going to be located on the MFP Control PWB.
        Sorry, I can't tell you which socket. =^..^=
        • DINGO
          • 661
          blackat4866
          was what I wanted to confirm, but I've looked into the control board, and do not seen
          any soket, likes as in ar-m450n for ex.
          the dims are the sames.
          • OMD-227
            Dingo,
            ARM351/451 comes with 128Mb standard. This can be max'ed out to 284Mb with the use of MXAR128SO & MXAR256SO memory module upgrades. These are different from the fax memory modules, which is AR-MM9 as Dave has already mentioned.
              • 23006
              My apologies. I made the assumption that Jupiter series here in the US were the same as yours. Apparently that's not the case.
              • DINGO
                • 661
                thanks friends, and do not worry, blackcat4866,
                thanks
