SHARP ar 507
  • copierdynamics
    • 5
    SHARP ar 507
    shows "INSTALL DEVELOPER UNIT" on display screen. Installed same unit as removed. Checked harness and pin connectors Next step is control/logic board. Any suggestions?
    • 23006
    Are the rollers in the developer unit turning? Perhaps you've lost drive to the developing unit. That's a relatively common failure of the main drive pack. =^..^=
