AR-DU4 + AR-FN7
  • vlad_
    • Jul 2008
    • 98
    AR-DU4 + AR-FN7
    Good afternoon.
    I have: AR-M451N, AR-DU4, AR-FN7 ........
    Factory withdrew from the production of AR-DU3. Need to make friends AR-DU4 and AR-FN7.
    If you remove the node bypass, then the idea should work, but will need a piece PCOVP1570FCZ3 a plastic cover for the bend and the direction of the paper. Price code of a simple plastic cover - BH!!!! (ADU cover lower) is probably a typo in the directory, but Sharp did not recognize their spelling and never asks for it oplait exactly that price. Is it possible to dispense with this plastic cover?
    Need ideas. "
  • jpcopy
    • Apr 2006
    • 256
    I would like to dispence with that cover but haven't figured out how. I have tried to buy and the newest part number I can find comes back no longer available. if you find any thing let us know
      • 23009
      IIRC the cover is required. I did not know it has gone obsolete. =^..^=
      • bilyahn
        • Dec 2006
        • 1470
        I agree with blackcat. You should be able to get the cover with no problem. This model series was still in production in 2009 as I just installed several new ones last year. Although all had the ARDU4 bypass with the FN6. The ARDU3 is also used with the MXM350 series as well.
        Good luck.
        Bil
        • CBMWilson
          • Sep 2010
          • 53
          I just checked parts and that part has actually been discontinued. PCOVP1570FCZ3.
          "Quantity requested is greater than current availability.
          You may still place your order and Sharp will work to get you the part as soon as possible.
          This part has been discontinued."
          I don't see any bulletins about the number changing and as far as i know they still are making these.
          • vlad_
            • Jul 2008
            • 98
            Today, carefully examined all the options. You can do without the plastic cover. But the appearance will be spoiled. It was decided to order a cover. The order was adopted computer system of the European Sharp. The price of this piece of plastic has turned out more than $ 200. Robbery!
            All thank you very much.
            • lky1978
              • Mar 2009
              • 483
              Originally posted by vlad_
              Good afternoon.
              Need ideas. "
              vlad, can you help me to find out ar-du3 main body frame?i cant find in part guide. mine got 3 units cracked. thx
              • SwisSeV
                • Jan 2016
                • 307
                Re: AR-DU4 + AR-FN7
                I just fixed one of the AR-DU3 units with the cracked plastic frame.
                Just thought I would throw the part number up here since it's in front of me and not in the part manual.
                ADU Base- LDAIU0628FCZZ price is (BZ)
                That's right BZ for this plastic POS.
