Help me, my sharp AR-M420U L4-02 error but when I use the SIM 14 to remove and pull the mirror frame above the end of the machine error, what can I do to the machine off error? people help me! thank everyone in advance!
AR-M420U error code L4-02
There are a lot of things that can cause an L4-02 code. If it doesn't reset with sim 14 check your drum unit. Something could be clogged in your waste toner auger or your waste toner container could be full or just something wrong with the drum unit.
Good luck.
BilComment
Is, like bilyahn said, first you must chek if all is ok in the drum unit, if nothing is arrested, and try replace the mc unit.
if everything is ok with the drum unit, then you must chek the main drive unit.
here are the most common causes of l4-02.
good luck.Comment
sharp finally sent out a memo about this. something about a binding developing unit. if your drum unit and fuser are good, check the dv unit and turn it manually to see if it hesitatesComment
