Sharp MX2300/2310
  • GeorgeBest
    • Jul 2009
    • 526
    Sharp MX2300/2310
  • ZOOTECH
    Senior member of CRS
    • 3375
    Originally posted by GeorgeBest
    Installed this machine, with scan to email.
    There is also a fax-unit installed. Customer wants the incoming faxes not print but sent forward to email. I can't configure this, not by webinterface or “system settings” on machine. Is this option is available on this machine ?
    Someone . . .thanks in advance
    It is on the web page under Application Settings - go to Inbound Routing to set up your email address. You can check the op manual for the fax option and see how to set up Inbound Routing.
    • tmaged
      Owner/Service Manager
      • Oct 2008
      • 1885
      It's pretty easy. Follow Zootech's advice. The only thing I would add is the tables & email all don't work like you think they would.
      Hope that helps !
      -Tony
      www.dtios.com
      Become a fan on Facebook
      • The Otrain
        • 54
        ...Also, make sure to add the email address to the address book 1st, and then set up the inbound routing. Once address is set for inbound routing it cant be edited or deleted unless you turn inbound routing off.
