Ar 550N 1st page bleeding through to 2nd page on duplexing through auto feed(only)
  • Ricoh Dicoh
    • Dec 2010
    • 62
    On this 550 you can almost make out what the 1st page says on the 2nd page with how much it's bleeding through. I think it has to do with the Cis or maybe the exposure...not to sure.
  • Silvertoast
    • Feb 2010
    • 270
    sounds like ur exposure is way to high, i have seen this b4 and lowered the exposer for the feeder in sims and solved the problem
      • 22999
      Yes, exposures can be adjusted independently for each side, each original type, 50+ different ways.
      The key to doing this adjustment is to start by identifying the default modes, then adjusting those. =^..^=
      • bilyahn
        • Dec 2006
        • 1470
        Also performing white reference adjustment sim 63-2 can help with the bleed through.
        Good luck.
        Bil
