Help with Network Scanning with Sharp AR-M155
  • cheeseus
    • Sep 2010
    • 36
    Hello,
    I have just installed the Network Expansion Kit (ARNB2N) on my printer and after hours of struggling I managed to get it to print from my PC (cable link to router) and from the laptop (wireless). However, I haven't had any luck with the scanning part.
    The manual says that scanning is only available if the computer is directly connected to the machine via USB. Does this mean that I lose the scanner if I want to have the printer as a separate device on my LAN?
    If I try to scan from the machine, the following appears on the display:
    SCAN USING:
    INPUT ADDRESS / GLOBAL ADDRESS (changes when I press the arrows).
    I remember that it said SC1 / SC2 / SC3 etc. when my computer was runing XP (Win 7 x64 - now).
    The machine description says: "Network Printing/Scanning" so scanning must be possible one way or another, but how?
    Before I got the Network Kit I was using SharpDesk 3.2.
    Any advice would be welcome
  • ZOOTECH
    Senior member of CRS
    • 3378
    With Win 7, you'll need SD v3.3; but Sharp does not support wireless scanning to my knowledge.
    • cheeseus
      • Sep 2010
      • 36
      I didn't have any issues using SD 3.2 on Win 7 before - when the PC was connected to the machine via USB.
      Now when I launch SD and try to acquire from the scanner, it says "The machine is not connected."
      I don't want to be able to scan via wireless. I want to be able to scan from/to the PC. The connection here is: PC to router - router to machine.
      I guess SD cannot connect to the machine via the router. But if the official specifications of the MFP say Network scan (scan to e-mail/FTP server/desktop)" there must be a way.
      For example, what do I write for INPUT ADDRESS or GLOBAL ADDRESS? I tried inputting the machine IP but this didn't work.
      • divad2k1
        • Sep 2010
        • 147
        Can you access the copier internal web page ? So you can configure scan to email /ftp...
        Usually input address = u enter an email adress manually
        global adress = ldap
        • cheeseus
          • Sep 2010
          • 36
          I just managed to access the machine internal webpage - I realized I was typing the wrong IP.
          But it won't let me in - I don't know the user name/password. I looked in the manual but there's no mention of the default user name. I tried the device name (Q41116) and the default password mention in the manual (Sharp) but these didn't work.
          EDIT: admin / Sharp --- did the job. I can login now. I am not sure what settings I need to make, but that's still some progress
          I also tried "LDAP" for global address but the machine says: "Searching... Network Error CE-02".
          Before that I tried writing "SC1" and "SC2" and "192.168.0.100" (the PC IP) for "input address" - it seems to accept these, lets me set the page size and then says "scanning..." after about 30 seconds it shows the above error.
          EDIT 2: I am trying to enter a Desktop Destination from the Destination Management page but everytime I try to save my input, I get the following error:
          "ERROR[937]: Scanner is in use now. Cannot service request. Please try later."
          I tried restarting the machine. No change. Interestingly, I get the same error when I try to add an Email Destination as well.
          • bdcrandall13
            • Sep 2010
            • 236
            Make sure the machine is at the "copy" screen when trying to edit things from the web page. I know on the newer machines it will not save any settings unless you are on the copy screen on the MFP.
            • cheeseus
              • Sep 2010
              • 36
              Changed to "Copy" and I was able to write the new destination!
              I added a Desktop destination - my PC, with its IP 192.168.0.100 - it appeared on the list of destinations as "001".
              I then tried inputting "001" for "Input address" and for "global address" but all I get is the "Network Error CE-02".
              • ZOOTECH
                • 3378
                In the Network Scanner Tool at the PC, > Profile tab, uncheck any profiles and apply. When the response is successful, recheck the profiles and apply. It should come back with a successful response, this re-establishes the MFP with the PC. I really think you'll have troubles though with WIN 7 without the SD v3.3.
                • cheeseus
                  • Sep 2010
                  • 36
                  I don't think I have the Network Scanner Tool... I read that it is bundled with SharpDesk, but I don't see it as a program entry, nor can I find it within SharpDesk.
                  When installing SharpDesk, is the NST an option? I may have unticked it because when I installed SD I didn't have the Newtork Expansion Kit. If "yes", will reinstalling SD help?
                  • ZOOTECH
                    • 3378
                    Open SD and under the Tools drop down at the top, go to Product Configuration, you'll find NST there.
                    • cheeseus
                      • Sep 2010
                      • 36
                      The Product Configuration option is greyed out
                      Guess that means I need to find SD 3.3?
                      • bdcrandall13
                        • Sep 2010
                        • 236
                        It is installed when you install Sharpdesk. If you browse the start menu under programs/sharpdesk the network scanner took should be in there. Opening this up and running it should input the address entries into the machine for you.
                        • cheeseus
                          • Sep 2010
                          • 36
                          It's not in the Start menu Sharpdesk folder. There are only these items there:
                          1. Sharpdesk Imaging
                          2. Sharpdesk
                          3. Start Index Status Display
                          4. Uninstall
                          I also looked in the installation directory in C:\Program Files (x86)\Sharp\Sharpdesk. The only thing which seems close is "NetScanProcessDef.dll"
                          • bdcrandall13
                            • Sep 2010
                            • 236
                            Do you have/need a copy of SD 3.3? I believe it is just an upgrade from 3.2. It uses the same serial #.
                            • cheeseus
                              • Sep 2010
                              • 36
                              The machine I have, the AR-M155 is only offered with SD 2.7. I will ask a Sharp technician if he can find me SD 3.3 with serial. The version I have now, 3.2, didn't ask me for a serial during installation.
                              Isn't there a way to change whatever needs changing without this network tool? I mean, the settings may be written in an editable text file...
                              EDIT: I just read in a post here that Windows Firewall could be blocking the connections, which would return the CE-02 error code. However, I remember allowing the machine to access the internet when asked by Firewall.
