EE-EL
  • kentong
    • 15
    EE-EL
    hi all brother, i got 1 machine 2010u i starting set up the deve, i run the 25-2 after come out error code EE-ELfor bk, any idea? thanks alot
  • mojorolla
    The Wolf
    • 2616
    Error display Content Details of content
    EE-EL EL abnormality Sensor output level less than 67, or
    sensor control voltage level over 197
    EE-EU EU abnormality Sensor output level over 154, or sensor
    control voltage level less than 49
    EE-EC EU abnormality Sensor output level less than 95, or
    sensor control voltage level over 105
    You can also go into SIM 7, turn off DV checking, run 200 skyshots, then check your outputs and voltages.
    Or get a new DV unit.....
    • bilyahn
      • Dec 2006
      • 1470
      It's means the unit is overtoned EE-EL or EE-EU code. You can try to run the 25-2 again but what model is this for? Unlikely but could be bad developer.
      • lky1978
        • Mar 2009
        • 483
        Are u run the sim 25-02 with toner cartridge installed?for sharp Gemini and Aries series please dont run sim 25-02 with toner cartdrige installed.Or try to change the bk developer.
        • lky1978
          • Mar 2009
          • 483
          Bil, is sharp latest entry level color mfp model mx-2010u
          • bilyahn
            • Dec 2006
            • 1470
            This is from the MX2310U SM for steps to fix this. You can run sim 25-1 to get a reading on the DV value. I would check the developer unit first. Is this a new install?
            Trouble content The sampling level in the automatic toner density
            adjustment is 76 or less or the control voltage is 208
            or above.
            Detail PCU
            Cause Toner density sensor trouble.
            Developing unit trouble.
            PCU PWB trouble.
            Check & Remedy Replace the toner density sensor.
            Replace the developing unit.
            Replace the PCU PWB
            • bdcrandall13
              • Sep 2010
              • 236
              I have had 2 previous models brand new out of the box that had a bad DV box. One was Cyan, one was Magenta. Could just be a bad DV box.
              • mojorolla
                The Wolf
                • 2616
                Agree with Bil,,,run SIM 25-1. If the reading is really low, below 76, or really high, over 208, you most likely have a bad developer unit. I too have had a few DV units bad out of the box.
                • glewisme
                  • Nov 2009
                  • 240
                  Hey,all did you have the toners in the machine when you ran 25-2. If so there's more than likely your issue.I've heard just a couple of grams falling into the dv unit during 25-2 will ee-el out on you and the only resolve is to replace the DV.
                  • kentong
                    • 15
                    i change the DV,is OK,thx all brother
                    • nellie
                      EE-EL
                      This has been caused by the wrong set-up procedures, when this machine was launched I like you set-up the machine much the same as all other mx type of machines, after a day or two the machines shut down. the devs were now shot and i had to replace them, but while waiting for stock to arrive a update arrived from sharp with reference to the set up procedure. when adding the developer for the first time to the developer box you must shake the dev box from side to side to ensure that the developer has been spread evenly,
                      once done and before adding the toner cartridges to the machine run code 25 2, once done ca let the machines now warm up without the toner cartridges in, then put the toner in.. its basically caused by the toner adding to the dev box before set-up has finished, a update for later models has now been done. hope this helps as its an expensive mistake..
                      • vlad_robas
                        • Oct 2006
                        • 225
                        I have installed 2 * 2310 and on both i had to clean, one ore more, DV senzor becouse when i run 25-2, first and second time, it showed me values around 70-80 instead 128 and afther i did clean the sensor and the value came around ~ 120
                        • Victorosani
                          • Nov 2022
                          • 11
                          Re: EE-EL
                          Congratulations!
                          I have a similar machine (DX-2000U) with EE-EL error too. my mistake was running sim 25-02 with the toner cartridge in the machine. I noticed you have EE-EL on for bk while mine comes out on all the developers.
                          what model of DV is your machine using ?
                            • 23008
                            Re: EE-EL
                            Originally posted by Victorosani
                            Congratulations!
                            Did you notice that the last post in this thread was 11 years ago? I was here 11 years ago, but a lot of members have come and gone since then.
                            Perhaps it would be a good idea to start a new thread? =^..^=
