sharp AR-M236
  • technician
    • Aug 2010
    • 25
    sharp AR-M236
    hello everbody
    In the sharp AR-M236 error display U9 subcode 99
    how to reset this code
    THANKS
    • 22930
    How interesting! U9-99 is an operation panel language error. Did you, by any chance, change the display language recently?
    The manual says to set the machine destination in simulation 26-06. There does not appear to be any list of destinations in the manual to choose from. =^..^=
    There is another possibility:
    - U9-99 can occur if the incorrect firmware is installed, such as DSK firmware on a non-DSK machine, or vice-versa.
    - Make sure the correct version of MCU firmware is installed for the country located. Firmware obtained elsewhere will also give U9-99. Reload the MCU firmware with correct F/W.
    - Set correct language in sim 26-22 to match firmware file of origin.
    Last edited by blackcat4866; 03-25-2011, 03:57 AM. Reason: Amazingly, I had another thought. Two the same day.
    • JustManuals
      • Jan 2006
      • 9838
      Just Manuals | The Internet's largest selection of manuals | Instant Downloads
      Paul@justmanuals.com
      • technician
        • Aug 2010
        • 25
        if you any solution tell me. dont ask to purchase please
        • technician
          • Aug 2010
          • 25
          thanks brother.
          after i can check language and country then i will tell you.
          but there is no firmware installed recently.
          soo i wish to find out the problem
          thanks again
          • DINGO
            • 661
              • 22930
              What setting did you use for 26-06, for which language?
              • DINGO
                • 661
                Blackcat4866, i mean that you are 100% right, already happened to me a lot of times, and always was the 26_06 choices wrongs, destination vs language.
                enjoy your weekend
