Sharp AR-157E L1 code
  • tcypy1961
    • 773
    Can an L1 error code on a Sharp AR-157E be caused by a damaged ribbon cable? I ask because the ribbon cable is bunched up under the scanner and it doesn't appear to be right like that. Also, if this is the problem, will the ribbon cable from a Sharp AL-1631 work in this copier? Any help appreciated, thank you.
    • 23008
    The L1-00 code is caused by the scanner not being able to reach home position. The ribbon cable can prevent the scanner from reaching home position. Also dirty scanner rails can cause this. Even more likely, the scanner lock has just been turned, preventing the scanner from moving. =^..^=
    • bilyahn
      • Dec 2006
      • 1470
      Also check the 2 small black plastic covers that protect the ribbon cable. Sometimes these will come loose and jam the machine, they are held in place by some packing tape. I have had this problem on a couple of these models. I believe the ribbon cables for these 2 models are interchangeable.
      Good luck.
      Bil
      • Dark Helmet
        • May 2009
        • 853
        As posted above, those are probably the issue. Were the ribbon cable connects to the CCD, they put a small bit of that stringy packing tape. Ive seen that peel back and then when the scanner moves back and forth the tape sticks to the slack ribbon cable and then starts backing it all up.
        • DINGO
          • 661
          hello,
          if you already verified all was posted above without sucess, that was a most probably cause, i knwon that have a boletim about L1-00, that was a replace resist in the main board.
          Sorry, i do not have this boletim.
          good look
