sharp arm 455 code f6-97
  • tlc1234
    • Jul 2010
    • 14
    i switched a sharp ar-m450n fax board into a sharp ar-m455n and got code F6-97. fax function trouble. can someone help me with this?
  • igi
    • 1507
    hi
    personally never had this fault
    but for what it worth,here is the description of your trouble
    9
    7 Content FAX-BOX skating trouble
    The FAX-BOX PWB is not one for the
    AR-FX12. (FAX detection)
    Detail The FAX-BOX MODEM controller is not
    one for the AR-FX12.
    Cause The FAX-BOX Modem controller PWB
    information (hard detection) is not for
    the AR-FX12. (The Modem controller
    PWB for the AR-FX5 or the AR-FX6 is
    used.)
    Check and
    remedy
    Check the FAX-BOX modem controller
    PWB.
    Replace it with a modem controller
    PWB for the AR-FX12.
    good luck
    • divad2k1
      • Sep 2010
      • 147
      arm450 = ARFX5
      arm455 = ARFX12
      • lky1978
        • Mar 2009
        • 482
        there are totally different.....u now trying to fill diesel into gasoline engine
