i switched a sharp ar-m450n fax board into a sharp ar-m455n and got code F6-97. fax function trouble. can someone help me with this?
sharp arm 455 code f6-97
hi
personally never had this fault
but for what it worth,here is the description of your trouble
97 Content FAX-BOX skating trouble
The FAX-BOX PWB is not one for the
AR-FX12. (FAX detection)
Detail The FAX-BOX MODEM controller is not
one for the AR-FX12.
Cause The FAX-BOX Modem controller PWB
information (hard detection) is not for
the AR-FX12. (The Modem controller
PWB for the AR-FX5 or the AR-FX6 is
used.)
Check and
remedy
Check the FAX-BOX modem controller
PWB.
Replace it with a modem controller
PWB for the AR-FX12.
good luck
