mx3500
  • bonnie750
    • 302
    mx3500
    Hello out there
    I've got a mx3500 throwing POD_1 S jams. only does it when it's hot, after say 50 copies.allow the m/c to cool and it's away again until it is hot. it has the latest reverse pg fitted. i reckon it's the POD sensor breaking down when hot. anyone had this fault???
    Bill
  • wtroll
    • May 2008
    • 85
    Originally posted by bonnie750
    Hello out there
    Bill
    Hello,
    I've already seen this issue, in my case was the POD1 actuator sensor that had difficulty to return to the home position specially when MFP was hot. Clean the actuator and give one more turn to its spring.
    Also try to swap POD1 sensor (code: VHPLG248NL1-1) with another identical sensor (like the SHIFTER HOME DETECT sensor).
    Regards
    • igi
      • 1507
      hi
      besides the sensor problem,if the copier overheats
      clean filters and check your fans turning
      ta
      • bonnie750
        • 302
        hello out there
        Fixed!!
        changed pod_1 sensor test 500 ok
        thanks
        bill
        • wtroll
          • May 2008
          • 85
          Well, good job!
          Have a nice week-end.
