Sharp MX-550N Finisher ?
  • scomeau1
    • Mar 2011
    • 100
    Sharp MX-550N 550-N Copier G3 Fax Print Scan w/Finisher | eBay
    In this photo the gap between the finisher and the main unit has a larger gap at the
    bottom could this be a problem ?
    Also I need to install the hole punch kit ARPN4B 3-hole Punch Unit,
    Has anyone installed this punch unit?
    Thanks Scott
  • divad2k1
    • Sep 2010
    • 147
    First of all, in the picture its a MXM550 not a MX.
    The gap between the finisher and the copier can be a problem if left like this but its a easy fix...you only have to adjust the height of the finisher.
    Punch unit installation is really easy and take a few minutes.
    • scomeau1
      • Mar 2011
      • 100
      Why is he listing it as an "You are bidding on a Sharp MX-550N Copier" then ?
      What is the difference between the two models ?
      Thanks Scott
        • 23009
        It's a mistake in terminology. I had to lecture our dispatchers that "550" is not enough. There is an AR-M550U, AR-M550N, FO-DC550, MX-M550U, MX-M550N, ... you get the idea. It's just sloppy description.
