Sharp AR5132 (E7)
  • alexi_issa
    • 10
    Sharp AR5132 (E7)
    hello sorry can any one help me about code E7 in Sharp ar5132
    & 10x
    • 23008
    The whole code please...
    E7- what? Hold the print button to see the remaining two digits of the code.
    • imaginGuru
      check this
      Sharp AR 5125/5132
      ERROR
      E7 Subcode 02: Laser Problem.
      10: Black correction shading problem from CCD
      11: White correction shading problem from CCD
      12: Intermediate tone shading problem from CCD
      13: Exposure light amount incorrect( can be blown exposure lamp).
      Now, in english:
      The lens of the machine (CCD) is not "seeing" correctly the white strip located underneath the exposure glass, this may be because of accumulation of dirt in optical section+lens. OR/AND the exposure lamp is dirty/blown (or its fuse).
      Laser bad is very unlikely but still possible.
      Check al these out and let us know what resulted. A full cleaning service should be the first step.
      imaginGuru
      • Mhir
        E7 sub code 13
        hello i've done cleaning all the optical parts of the exposure lamp but i do recieve the same error message, there is any other way to find out the best solution for this? E7 subcode 13. tnx a lot in advance.
          • 23008
          I would start out by changing the exposure lamp. =^..^=
