Sharp Drum Kit help Please : )
  • kjesson2009
    • Jan 2011
    • 21
    Hi,
    So I have a Sharp AR-M450n+ and I am wondering how long a drum kit lasts for?? I just had it replaced last month & did 47,000 impressions and now the drum is shot and I need another drum kit
    My questions is are all drum kits for this machine 50,000 impressions??? I have been looking online for them and I keep finding the sites say they yeild 100,000. I have been buying my drum kit from a local place in town & when I asked him he says they only come in 50,000 and the 100,000 ones are scams????
    I am in Canada so if anyone knows a good place I could order my own drum kits online that are legit! I would really appriciate it : ) Thanks for any help or advice!
  • ZOOTECH
    Senior member of CRS
    • 3378
    The AR-450DR OEM is rated at 50k, but depending on usage and condition of machine it may last a lot longer or shorter length of meter count.
    • Wild Bill
      • Jul 2005
      • 774
      Check Katun but they are aftermarket; good quality drums though
      Izzy
      • bilyahn
        • Dec 2006
        • 1470
        Use the AR451DR drum it is rated at 100K and comes pretty close most of the time but even with this drum I have had to replace it at 65 to 70K before.
        Good luck.
        Bil
          • 23010
          Good luck.
          Bil
          I've had similar experiences. Avoid aftermarket drums & blades. =^..^=
          • bonnie750
            • 302
            Got to agree.....om parts if at all possible
            Bill
            • Silvertoast
              • Feb 2010
              • 270
              yup per the manual 50k, we use the katun ar-451 drums also and they typically last to about 100k, have a few in the field that have gone closer to 200k with no problems and excellent copy quality. will also depend if ur doing alot of 1 copy jobs rather than longer jobs.
              • Dark Helmet
                • May 2009
                • 868
                When that machine was launched it came with a 50k drum and 100k DV. They then switched to a 100k drum. When you went to the 100k drum you had to change some values in sim 44 so process control could adjust for the 100k drum. You also need the new style drum pawls that are included in the AR450KA M-kit
                Description: A 100K PM Cycle drum is now available for use in the above listed machines.
                Details: The following 4 requirements Must be met to adopt the 100K PM Cycle.
                To determine if the machine is already configured for the 100K PM Cycle.
                1) Engine Firmware must be at version G00 or higher.
                As your machine is a ARM450
                44-1 = 255
                61-2 = 100
                61-3 = 100
                61-4 = 100
                21-1 = 100
                26-38 = 0
