ar-m505 error U2 sub code 40 will not reset
  • RICFOWLER
    • Apr 2011
    • 25
    [Error Code] ar-m505 error U2 sub code 40 will not reset
    ar-m505 error U2 sub code 40 reads as a CRUM chip communication error will not reset with simulation 16 can anyone help me out
  • bilyahn
    • Dec 2006
    • 1470
    Replace the toner. You have something wrong with the toner that you put in the machine.
    Good luck
    Bil
    • ZOOTECH
      Senior member of CRS
      • 3375
      The connector on the toner hopper that receives the toner bottle may be slightly off perpendicular causing a bad read.
        • 23002
        Is it safe to assume that you have an AR-M550N or AR-M550U? I don't think that there is an ar-m505. And it's probably not an AR-505. Most of the Cougars are long dead. =^..^=
        • ZOOTECH
          • 3375
          Yes, most are thank goodness, but we still have customers that will not upgrade until it is absolutely necessary.
