Hello everyone,
I'll try to make the story short, a client of the company to whom i work for has an mx-2300 that we started servicing not long ago, the machine has very little work (the first intervention i did was to replace the lower fuser roller because it was "square")...
Anyways last friday the client pressed the standby button on the keyboard, and before the machine had done the full powerdown, pulled the plug!!!
After that the machine never worked again, just triggering an E7-03, wich according to the SM means hdd failure...
I dont have experience with this machine, related to this problem. so we hauled it to the importer here in Portugal to get some assistance with it, they went to another machine (same model) took out the HDD and putted it in the defective machine, did a sim 14 to clear the E7-03, then a sim 16 to clear the U2-05 and truth is the machine was working... They told me if we wanted a new HDD Sharp would charge a fortune for it, so i'd be better off putting a new one in it myself...
All fine and well, tho it didnt worked that way... the SM is very vague when it comes to replacing the HDD... From what i was told by the tech when installing a new HDD we reset the 7-03 then the U2-05 (wich seems to be HDD data mismach) we do a sim 62 to format the HDD and then we can do a data import to restore client data (well the data is non existant, the client doesnt use scanner nor printer, uses it just as copier) but the machine doesnt let me do that... i installed a brand new hardrive (original hdd was a 40Gb Hitachi... i tried 4 new HDD's, different sizes, 40, 80, 120, 160 Gb diferent brands and the machine just puts out the e7-03... and doesnt let me format the HDD...
I honestly done believe that its this hard to replace an HDD... and i fear that there might be something more wrong with this machine... it did work with the hdd from another machine, but i cant get to make it work with a "blank" hdd...
The machine does tamper with the HDD (tho when i try to format it the machine throws out a NG result) i plugged the hdd to a comp, and saw 2 partitions made one of exactly 10Gb and the rest on a second partition... tho they arent formatted its just unallocated space, witch i find weird since SM seem to say the machine works with FAT32 system?!
So if anyone would be kind enough to shed me some light on this matter... the distributor was of not much help at all, tried an hdd from another machine on it... worked... and sended me home "just replace the hdd"... but either im being really dumb here or there's some trick to it... or what i fear is there's some other background problem here that i simply cant pinpoint due to the lack of experience on this matter... Thanks alot in advance
