Sharp MX-M620N Driver Install Help
  • DINGO
    • 661
    #16
    do you try ping the copier ip? if you get an positive answer you are doing something wrong, if you do not have a ping answer, you must check this first.
    about the finisher, you must configure first the copier in the drive with the copier configuration.
    About instal the copier you try using the exe. and can try manualy, if you downloaded the drives, you must unzip them first.
    In the manualy instalation,you found the drives of corse, in the destination that you put them, but if you d`ont found the drives, you have the possiblity that install a windows default drives.
    good look
    • scomeau1
      • Mar 2011
      • 100
      #17
      I'm trying to connect the MFP VIA USB not network so I can ping it.
      • mojorolla
        The Wolf
        • 2583
        #18
        Along the top row of the print driver is a configuration tab. You must check the options for the machine to see the finisher and other options.
        • scomeau1
          • Mar 2011
          • 100
          #19
          Thank you all for your help ! I got it.
