Surge Protection for Sharp Copiers ?
  • scomeau1
    • Mar 2011
    • 100
    Looking for power protection for the Sharp MX-M620N
    Can anyone recommend any ups or power strips ?
    Thanks for your help !
  • ZOOTECH
    Senior member of CRS
    • 3375
    Try the Panamax MIP-20A-EX; it will work on a GFCI circuit unlike the ESP boxes.
    • mojorolla
      The Wolf
      • 2609
      NEWesp.pdf This is the new ESP box. It has a built in monitoring system. You can plug it in via USB and see what the outlet is doing during the day. You can also set thresholds. Pretty neat.
      • glewisme
        • Nov 2009
        • 240
        SmartPower systems!! Transformer based !! Been using them for years never had an issue. NA Trading is a dealer of these. You won't be disappointed.
        • scomeau1
          • Mar 2011
          • 100
          What is a good EPS model to get for the Sharp MX-M620N ?
          Thanks Scott
          • scomeau1
            • Mar 2011
            • 100
            I was looking at the broshure and it looks like it just has the 15 AMP plug not the 20 amp for MFP That I would need. Not 100% shure
            • mojorolla
              The Wolf
              • 2609
              Comes in 15 and 20 amp. XG-PCS-15D or XG-PCS-20D
              respectively.
              • scomeau1
                • Mar 2011
                • 100
                Is this what you recommend for your MFP ?
                Thanks Scott
                  • 23008
                  Are you looking for surge suppression or power conditioning? There is a huge difference.
                  Surge suppression limits voltage to 250VAC, and does nothing for sags.
                  Power conditioning supports sags for brief periods of time, and can limit voltage to 150vac =^..^=
                  • scomeau1
                    • Mar 2011
                    • 100
                    I'm need what is best for the Sharp MX-M620N
                    But should I go with an Power conditioning system instead of a power strip ?
                    I'm not sure but at the price of MFP I don't want to skimp also hear.
                    Scott
                      • 23008
                      Me? I'd use a 20A ESP Surge Suppressor and confirm that the machine is on a dedicated 20A receptacle. =^..^=
                      • pjdbm
                        • Sep 2007
                        • 360
                        yep,what he said
                        • scomeau1
                          • Mar 2011
                          • 100
                          Where can you buy ESP online ?
                          • pjdbm
                            • Sep 2007
                            • 360
                            call them and set up an account.
