Sharp MX3500N - Error code : FK3
  • eLectron1k
    • Sep 2025
    [Error Code] Sharp MX3500N - Error code : FK3
    Hello guys, i'm new at forum and my first question is how to get in maintenance mode @ Sharp MX3500N?
    I tried to use #/P, *, C,* -> but it doesnt show anything..
    Thank you!
  • bonnie750
    • 302
    The FK3 code can't be cleared from there, the machine needs parts.
    Bill
    • igi
      • 1507
      hi fuser web cleaning needs to be replace
      and the correct counter cleared sim-24
      good luck
      • Akitu
        Legendary Frost Spec Tech
        • Oct 2010
        • 2595
        #/P -> * -> C -> * is the correct sequence, just make sure you're on the copy screen.
        • Dark Helmet
          • May 2009
          • 867
          That is the correct sequence to enter service mode. Make sure you are in copy mode when you try this. Image send or job status will not work.
          At 150k color & B/W copies added together the machine will call for a fuser web. At 300k you replace the entire fuser. Check the consumables section of the service manual, it will have the supply numbers you need that will come in kits.
          • eLectron1k
            All right.. thanks guys for your help. I will check these steps right now.
