mx-5500n image shifting
+ More Options
Posts
  • lightningjeremy
    • Jul 2009
    • 139
    black copies look good, color copies have a rainbow shadow. is there a calibration or adjustment for the individual colors? the colors appear to be about 1mm off from each other. thanx
  • wtroll
    • May 2008
    • 85
    • rayjeek
      • Jun 2010
      • 239
      I had the same misregistration for colour today. It was a sheared gear on the 1st transfer large roller. if you turn belt by hand it appears ok but upon unscrewing it, you will see the damage. Replace the gear.
      • lightningjeremy
        • Jul 2009
        • 139
        is the gear on the main transfer belt unit or the one on the fuser access door?
        • rayjeek
          • Jun 2010
          • 239
          The gear is on the primary transfer belt unit. You can find a spare one in MX700X1 maintenance kit.
          • lightningjeremy
            • Jul 2009
            • 139
            does anyone have the part number for the primary trnsfer drive gear?
            • DavePo
              • Jul 2008
              • 305
              Try NGERH1668FCZZ
