Office 2007
  • glewisme
    • Nov 2009
    • 240
    Office 2007
    Has anyone else experienced this issue? When trying to print to the bypass tray it will not pull paper from the bypass. We defaulted MS office word 2007 to the bypass tray,and it still doesn't take paper from the bypass. It has happened in numerous accounts. I have had this issue on the Mx2600 thru 5001 mostly. I know it's a glitch or setting in word cause everything else prints fine .
  • bilyahn
    • Dec 2006
    • 1467
    Have had issues with Word 2007 printing from the bypass but only as it applies to envelopes. Still haven't got that figured out! Do they have Service Pack 2 installed? That is a must have for Office 2007 as there are all kind of issues with it.
    Good luck.
    Bil
    • glewisme
      • Nov 2009
      • 240
      I'll have to check what service pack they're running, but they can't run cardstock or anything from Office 2007 to the bypass. This is an issue for us at numerous accounts.
      • divad2k1
        • Sep 2010
        • 147
        Not sure if this can help you but its worth a try.
        The printer settings are ignored when you print a Word document
        What i understand is you have to modify the page setup of your word document.
        • The Otrain
          • 54
          That's it. Sometimes it will also have an issue with Outlook 2007.
          • glewisme
            • Nov 2009
            • 240
            I understand that Word overrides the drivers settings;but when I manually change the default paper tray settings in word to the bypass tray,it refuses to pull from the bypass instead it pulls from tray 1. I even had their national IT head mess with all the settings in the word doc ,and default settings and still the same issues!
            • mansart
              • 852
              If you create a new document does this still happen? Will other apps pull from bypass?
              • efe311
                • Oct 2008
                • 114
                I TELL U SOME THING TURN ON TH MC.
                Tray setup
                (1) Simulation setup
                Change the tray setting in the "system setting" mode. If "Disabling
                of Tray Settings" has been enabled in the system settings (administrator),
                the tray settings (except for the bypass tray) cannot be configured.
                1) Press the [SYSTEM SETTINGS] key.
                2) Touch the [Paper Tray Settings] key.
                3) Touch the [Paper Tray Settings] key to configure the settings.
                These settings specify the paper type, paper size, and functions
                allowed for each paper tray. When the [Tray Settings] key
                is touched, a list appears showing the trays and the current
                settings.
                4) Touch the [Change] key in the above screen to change the settings.
                The following settings can be configured.
                (2) Tray size setup
                1) Pull out the paper tray.
                Gently pull the tray out until it stops.
                If paper remains in the tray, remove it.
                2) Adjust the guide plates A and B by squeezing their lock levers
                and sliding them to match the vertical and horizontal dimensions
                of the paper to be loaded.
                The guide plates A and B are slidable. Slide each guide plate
                while squeezing its lock lever.
                1
                2 1
                LOGOUT
                HOME
                IMAGE SEND
                JOB STATUS PRINT
                READY
                DATA
                DATA
                LINE
                SYSTEM
                SETTINGS
                Item Description
                Type Select the type of paper that is loaded in the tray.
                The paper types that can be selected vary by paper
                tray.
                Size Select the paper size from the list. The paper sizes
                that can be selected vary by tray. The sizes that
                can be selected may also be restricted by the paper
                type selected above.
                If the desired size does not appear in the list, select
                [Custom Size] and directly enter the size (only for
                the bypass tray).
                Feeding Approved
                Job
                Select the modes that can be used. If there is a
                function that you do not wish to be used with the
                selected tray, disable the function. When the "Type"
                is other than plain paper, recycled paper, colored
                paper, or a user type, [Fax] and [Internet Fax]
                cannot be selected.
                B
                • efe311
                  • Oct 2008
                  • 114
                  U can enable or disable evry casset for print , copy or or fax
                  i post u the setting fron the maneual service
                  • glewisme
                    • Nov 2009
                    • 240
                    They are all enabled the machines print all day long out of the bypass unless, it's a MS Office Word 2007 document. I've encountered this in more than one account! Other apps print to the bypass just fine!
                    • freginold
                      • Sep 2010
                      • 102
                      had this same problem. customer could print to bypass in Word 2007 but not Outlook. But by selecting the bypass tray in page setup when you go to print instead of in properties, the bypass worked fine.
                      Config page instructions for copiers, printers, & fax machines
