Mx 2300N leaving dark lines only in plain paper mode
  • arcdigi
    • May 2010
    • 32
    My sharp 2300N is leaving horizontal lines when printing to "plain paper" at the plain paper setting. It is perfectly clean if I print to 'Plain paper" at the heavy or label setting but then lose the ability to duplex. Any ideas where to start looking at why this would only be happening in plain paper mode...
  • igi
    • 1507
    hi
    the only diference betwen heavy and plain paper is heater temperature and speed of copier
    check heater settings
    if you do self print do you get the lines?
    if you make copy do you get the lines?
    good luck
    • arcdigi
      • May 2010
      • 32
      Temp is at specs..self test print, print or copy, I cannot even do the color calibration because its covered in lines
      • arcdigi
        • May 2010
        • 32
        Also it starts getting lighter as I run on plain paper but doesn't go completely away, and if I stop and start again it is as dark as when I started the first time....but the first one on "heavy or label paper" is clean.
        • divad2k1
          • Sep 2010
          • 147
          Is your firmware up to date
          If not, i recommend you upgrade it. There was some change in the fuser temp.
          Then go to sim 55-1 switch 2 and make sure bit 1 = 1
          Can you post an a scan of your problem ?
          • arcdigi
            • May 2010
            • 32
            Checking firmware
            • arcdigi
              • May 2010
              • 32
              The above was a scan of the problem
              • rayjeek
                • Jun 2010
                • 239
                Having seen your scanned photo, it appears a problem with black drum unit. Replace black drum unit MX27GUSA or use the kits.
