MX-B401 L4-16 error
  • stangmanok
    • Mar 2010
    • 15
    MX-B401 L4-16 error
    Hello all.
    I have to service manual for this machine but not the parts catalog. I am needing the fuser drive swinging gear assembly. The gear that drives the fuser is brittle and has teeth broken off of it. The said gear is attached to a swing plate assembly.
    If anyone could provide at minimum a part number it would be great! A parts catalog would fantastic as well. Additionally if anyone knows of a good vendor for Sharp parts please pass on the info. We are a Xerox and HP shop.
    Thanks for you time!
  • mojorolla
    The Wolf
    • 2626
    This code is almost always one of these parts:
    MLEVP1112FCZ3 or LPLTP7869FCZ1. Even after the improved flag, they still snap and give that code. The other is the pressure detect plate, which can crack but still appear functional.
    • Nachoman4life
      • Oct 2007
      • 212
      NGERH1982FCZZ is the gear, in the swing drive cluster, that comes into contact with the UH drive gear.
      Where the heck is my spring hook?
      • andrew sinclair
        hi there, the part number for the two drive gears on the swing arm are NGERH1983FCZZ and NGERH1982FCZZ but if your gear has broken then the chances are that the fuser unit has seized up. its commen and there are modified fuser bearings now. im in the uk but i think the part manuals are the same.
        • stangmanok
          • Mar 2010
          • 15
          Re: MX-B401 L4-16 error
          Which gear is which? The one directly in contact with the fuser's gear is which part number?
          • gwaddle
            • May 2009
            • 782
            If you haven't changed a fuser drive gear before, look really close up inside for the spring that attaches to the swing arm at the top. If you don't know it's there it will shoot off into the machine never to be seen again.
            I know I should be ashamed of myself. Strangely though, I am not.
            • chubblies
              • Jun 2011
              • 155
              Also, check the fuser to see if the bearing has seized or broken up. If it has broken up, bear in mind that the balls fron the bearing will have dropped into the machine, so it is well worth spending a bit of time stripping out all the process units and transfer to ensure that none of the balls have dropped near the process units, or you can cause a lot of damage in the blink of an eye!
              • pbbsinc
                • Nov 2005
                • 92
                In addition to all of the above, I have found many fusers where all of these items are fine (& some where techs have replaced some or all of them) & the fuser still frequently fails to pressurize or release, generating the L4-16 code. The ratchet system consists of 2 one way bearings, one in the ratchet arm, & another at the other end of the shaft, If the one in the arm fails, the shaft wont turn, but if the opposite one fails, the shaft will wobble back & forth until the machine times out & throws the code. I just (because I was tired of ordering fusers at far below their yield) pulled several "bad" fusers off of the shelf & ripped into them. After cleaning & "scotch-briting the shafts under both, I now have a few more "good" ones. Hope this saves some of you a few bucks.
