Well, kind of. The finisher was on machine A and it was jamming. Finisher has broken part in stapler so tech decides to disable stapler and order part. When machine is turned on, the machine feeds a piece of 11X17 paper and it goes into the saddle stice unit and tries to staple, and jams. Figuring this is a stuck print job, the queue was cleared and machine was reset but still feeds a page when turned on. Tech then unpluged the network cable and reset machine, as well as re clearing memory. Still feeds paper.
Moved finisher from one machine to another machine. Turned machine on and it feeds a piece of 11X17 paper and jams.
QUESTION: Is this the machine trying to use a piece of paper to "reallign" the staple unit itself? Some machines feed a cleaning page, is that what's going on? I went through the finisher manual as well as the machine manual and I don't see anything about the phantom feeding.
Thanks for the read all.
Stacey
Stacey
