Sharp MX-M620N Error E7-03
  • scomeau1
    • Mar 2011
    • 100
    I just got the E7-03 code on the MX-M620N what can be done to fix this ?
    Thank You !
    Scott
  • igi
    • 1507
    Re: Sharp MX-M620N Error E7-03
    hi
    you got HDD trouble
    do sim to test all read and write
    and if not too importent info on the drive do format
    good luck
    • scomeau1
      • Mar 2011
      • 100
      I'm trying to do a sim code Main 62 Sub Code 6 to do HDD self diag on the hard drive.
      But after entering the service mode I can't get into the Main 62 I hit the start key but nothing happens.
      Do you guy's have any ideas ?
      Thanks for any help you can give me.
      Scott
      • JustManuals
        • Jan 2006
        • 9838
        This Parts & Service manual can be purchased for $12.77 and downloaded immediately after payment
        from http://www.justmanuals.com
        Paul@justmanuals.com
        • PASTech
          • Sep 2010
          • 192
          Try Sim 62-2 to see if the HDD is able to read/write. Check the HDD harnesses making sure to check connector pins making sure they are not bent in.
          61-1 is a HDD format. This might be the way out. It could also be a communication from the MFP control PWB giving errors but I am not sure how to determine this except by taking the HDD out and testing it on a computer or another copier. More likely a HDD error and hopefully you can re-format and with that fix everything.
          Hope this helps and Good Luck!!!
          What's Brown and Sticky?
          -A Stick
          • scomeau1
            • Mar 2011
            • 100
            Thanks for your reply sir,
            The problem now is that I can't get into sim 62 at all, when I hit the enter key nothing happens at all.
            I tried to do a sim 14 to clear the code and that rebooted the machine and then the E7-03 code came back.
            So is it time for a new HD ?
            Thanks for any help anyone can give me.
            Scott
            • ZOOTECH
              Senior member of CRS
              • 3375
              Scott
              Is it possible the HDD has been removed and that's why you can't get into sim62? Check with sim 22-10 to see if it's listed
              • scomeau1
                • Mar 2011
                • 100
                under 22-10 the hard drive is listed as OMB
                What does OMB mean ?
                Thanks Scott
                • igi
                  • 1507
                  hi thathmeans 0 mega bytes
                  missing or faulty replace
                  good luck
                  • PASTech
                    • Sep 2010
                    • 192
                    good luck
                    yup, looks like it needs to be replaced or if you have the capabilities to reformat it via another machine or if you have a USB to SATA/IDE Adapter you can format it via your computer. Worth a try to reformat, might just be corrupted data. Of course that is if there is actually a HDD on the machine.
                    I was given one of the following by a Long Time tech and found this to be handy when Hard drives go wonkie. It allows me to reformat with my notebook on site allowing for quicker diagnostics of the HDD problem and faster resolutions. It is as Manhattan Hi-Speed USB 2.0 To SATA/IDE Adapter. If you have regular issues with HDD I would recommend this in with your tools.
                    MANHATTAN : Hi-Speed USB 2.0 to SATA/IDE Adapter
                    Hope you get it working.
                    -A Stick
                    • mojorolla
                      The Wolf
                      • 2616
                      Have you tried formatting it in "super secret service mode"? However, if it shows 0mb, you most likely have a bad HDD.
                      • PASTech
                        • Sep 2010
                        • 192
                        shhhh...its supposed to be secret...don't tell...lol
                        -A Stick
                        • mojorolla
                          The Wolf
                          • 2616
                          After what happened to Wazza, my lips are sealed.
                          • PASTech
                            • Sep 2010
                            • 192
                            That is the better choice....I wish Sharp would relax and let Wazza come back....He was an valuable member of this community!!!! Sharp is being a little too sharp with him.
                            -A Stick
                            • scomeau1
                              • Mar 2011
                              • 100
                              Thanks for your reply !
                              I'm just thinking of swaping out the hard drive for a new on.
                              Not sure on the type of HD to get because I have not pulled it yet.
                              So most likely it's a SATA drive that the MX-M620N takes ?
                              Thanks !
