Sharp MX-M310 Scanner error 936 - Scanning feature is not enabled
  • ppiphome
    • Jul 2011
    • 12
    Hi all, hope someone can help. I have the above scanner and the demo scanning was activated. Now we have used up all the scanning. I am receiving the message "Scanner kit not installed". When connecting using a browser and going into Network scanning - then setup I receive a red error "ERROR[936]: Scanning feature is not enabled"
    I have called out our third party support and the guy hasnt got a clue. Tried ringing Sharp and they are useless as far as support is concerned!
    I have read that I should re-enter the machine serial before I can enter the scanner product key which I received but have not yet used!
    Is there a way to re-enable the scanning? What do I need to do?
    I would imagine all modern Sharp scanners to work using the same setup??
    Cheers and thanks in advance
    Phil
  • lky1978
    • Mar 2009
    • 482
    Re: Sharp MX-M310 Scanner error 936 - Scanning feature is not enabled
    u need to purchase from sharp mx-nsx1 scanner kit, of coz u need to give the copier serial no. to get the product key
    • johnbla
      • Apr 2005
      • 94
      IF you have the Scanner Product key for that machine...
      Enter Key Operator mode on the MFP Operation Panel and input the Activation key in Product Key โ€“ NSX or Scanner Expansion Kit, then Power cycle the Copier...... activation is now complete.
      Sharp UK will only provide Technical Support to Authorized Dealers and Sharp Qualified Engineers, your 'Third Party Support' is obviously neither....
      You will then need to configure the Scanning options...ensure that you are using a 'static IP address for the machine and the SC2 port if you an not using USB.
      I do hope you have a Maintenance contract with someone.....
      regards
      John
      sigpic
      " The Game never ends..When your whole World depends..On the Turn of a Friendly Card..."
      • ppiphome
        • Jul 2011
        • 12
        • igi
          • 1507
          hi you need to instal memmory then you will see scanning activation bar
          good luck
          • ppiphome
            • Jul 2011
            • 12
            Thanks for that. Will look into the memory ASAP.
            Cheers
            PHil
            • ppiphome
              • Jul 2011
              • 12
              I have checked the memory using a browser to connect and it states "memory and storage installed" = 64MB RAM. Not sure if memory is the problem unless I need more!?!
              Thanks again!
              • igi
                • 1507
                hi see attach
                good luck
                • igi
                  • 1507
                  hoi minimum 128 is neded
                  good luck
                  • ppiphome
                    • Jul 2011
                    • 12
                    Hi Igi, I didnt realise it needed 128 because the scanner trial period worked fine, I assumed that it should just work!
                    Cheers
                    Phil
                    • igi
                      • 1507
                      hi yes i know trial is free and no memory neded
                      proper activation memory neded,go figure
                      thats why we say japanise sense of humor
                      good luck
                      • ppiphome
                        • Jul 2011
                        • 12
                        Hi igi.
                        Just removed the back panel, theres no memory in the slot which is shown on the diagram you sent. Will have to find out the make of the RAM and order some.
                        Thanks a lot for your help, was totally stumped with this one!
                        • igi
                          • 1507
                          * Memory can be added by installing a commercially available 128 MB or 256 MB memory module (144-pin SDRAM
                          SODIMM).
                          good luck
                          • ppiphome
                            • Jul 2011
                            • 12
                            Hi igi.
                            You were spot on, put 128MB RAM and the scanner kit is now there under product key. The only issue is now it will not accept the key I have and this is the first time I have ever used it.
                            Not sure how to go about getting another key.
                            Phil
                            • igi
                              • 1507
                              hi turn off the demo simulation and try again
                              good luck
