MX-4501N intermittantly going offline
  • redserv
    • May 2010
    • 307
    hello guys i have a Mx-4501N going to offline mode aftre a couple off prints, if i power down the copier and power up again it works for a short time and does the same thing again, how can i start to troubleshoot this issue?thanks in advance
  • igi
    • 1507
    Re: MX-4501N intermittantly going offline
    hi latest firmware upgrade,is the first thing to do
    good luck
    • divad2k1
      • Sep 2010
      • 147
      Also check your maintenance counter.
      And try to disable SNMP on your print driver.
      • redserv
        • May 2010
        • 307
        thanks for the feedback guys i'll give it a go
        • Dark Helmet
          • May 2009
          • 856
          You can also stop SNMP notifications from the copier
          Sim 55-3
          SW 9
          Bit 5 = 1
          • redserv
            • May 2010
            • 307
            heya guys i was told by this client that the I.T. guy,changed the setting on the print driver from RAW to LPR, and now the problem is gone, the copier works normal without going offline, my question here is whats the differnce with RAW and LPR and how could that setting fix that issue that i asked about before, thanks again guys.
            • mojorolla
              The Wolf
              • 2627
              I always set my driver to LPR and enter a queue name of "lp". LPR is good for text like checks and invoices and can be used on a UNIX server. RAW is a ready to print format in the printers native language. Raw is good for PS printing.
