Hi all,
I just need a firmware for the SHARP AR-M207.
I've got the E7-11 error if I try to use the scanner with colors.
I've read other threads about this error and about possible solutions [1]
In particular what oeshuron and TechGeek said.
Just to let you know...
I've read the manual (section 12) about firmware upgrade.
I know that upgrading the firmware is a RISK and probably that it's not THE definitive solution.
Would someone send my a (I hope.. tested) firmware for the printer ?
A version after December 2006 should have this fix (as reported by TechGeek in [1]) :
Engine (From December 2006) The operating margin for occurrence of E7-11 error (Shading trouble /White correction) has been increased. Since the E7-11 error may occur due to fogging of the reflector, the E7-11 error detecting level has been decreased."
Registered members can email me,
Thanks in advance,
tortp
PS You are doing a great work with this forum.
Thanks in advance,
tortp
